Reallusion’s partnership with Faceware enables iClone to achieve real-time facial motion capture and recording. This will empower indies and studios of all levels, giving them access to facial motion capture tools that are fast, accurate and markerless--all from a PC webcam.
Fast, Accurate, Markerless Facial Tracking
Faceware Realtime for iClone - fast, accurate, markerleaa facial tracking
Faceware Realtime for iClone is a professional quality real-time facial tracking software designed to give iClone users a simple, cost-effective, and powerful tool for animating character’s faces. Use a capable webcam to live mocap or a pre-recorded image sequence to drive natural human facial expressions and head movement.
Capture Sources
  • PC Camera Tracking: Use PC cam or ProHD cameras to live capture facial animation.
  • Image Sequence: Convert any video for use as a facial tracking source, making production iterations convenient.
capture sources
facial motion capture from PC cam or image sequence
Camera Settings
  • Access to all available camera supported frame rate and resolution.
  • Recommended High Quality PC Camera:
    • Logitech Brio Ultra HD, 60 fps
    • Logitech HD Pro C920, 30 fps
  • Face Tracking Model:
    • StaticCam for desktop capture
    • HeadCam for head mounted capture
facial mocap camera settings
Fast Calibration
  • Calibrate on-the-fly, anytime without breaking the data stream.
  • 3 second calibration! Simply position the face in the center of the frame and hold a neutral expression!
fast calibration for facial mocap
Combine Facial Capture with Body Motion Capture
iClone Faceware Mocap Plugin - Combine Facial Capture with Body Motion Capture
The Motion LIVE system allows users to connect and combine, face, body and hand motion capture devices simultaneously. Streamline your production and save time and budget by recording all your performances in one go.
Tracking Data Inspector
  • Instant, dynamic feedback. These meters let you view your animation data in real time.
  • Observe the relationship between your facial performance and the real-time data stream and adjust the result.
Custom Capture Profiles
  • Define your own expression style with facial muscle sliders and save it as a Custom Capture Profile.
  • Default 60-morph capture profiles are optimized for StaticCam and HeadCam.
  • Take advantage of the Search function to quickly access sliders.
Feature-based Facial Strength Filters
  • Globally or separately control the signal input strength for brows, eyelids, eyeballs, mouth, jaw, cheek, and head rotation.
  • Easily capture stylized characters with proper strength settings for toning down or exaggerating features.
  • Save settings for characters.
Face Mask for Blend and Isolation Capture
  • Isolate facial features to either mocap the full face, or just capture certain features or muscles.
  • Do multi-pass editing to blend up selected feature movements.
Smooth Head Movement
  • Head jitter sometimes occurs while performer has high frequency facial motions. Check the Smooth Head function to reduce the jitter and smooth out the head movement.
Synchronous Audio Recording during Facial Capture
  • Optionally record audio with the face capture session.
  • Recorded audio generates lip synch data.
  • Blend lip-synch and motion capture to create the best result.
Motion Editing & Refinement
iClone - motion editing and refinement for realtime faical animation
iClone updated the Character Creator 3D Character Generation Systems with up to 60 Facial Morph capability to fully animate the facial capture detail. Enhance subtle detail on facial muscle control and make iClone fully-compatible with the professional facial capturing standard provided by Faceware.
Optional Mocap Mouth Blend with Audio Lipsync Viseme
  • Audio to Lipsync Analysis gives another level of lips and tongue accuracy, and allows detailed Viseme editing.
  • With the options to choose the blend ratio between facial mocap and audio lipsync, and achieve the optimal result.
Refinement and Face Key Timeline Editing
  • Edit face capture performances in post with the iClone facial timeline.
  • Access the motion clip track to edit & offset with face keys.
  • Expression Intensity control through slider bars.
FBX Character & Animation Export
  • Take your characters with facial captured animation to any game-engine or 3D application.
  • The exported FBX characters keep full facial blend shapes, and their animation data in time sequence. You can re-edit them in other 3D tools for further possibilities.
FBX export to 3DS Maz, Maya, Unity, Unreal FBX export to 3DS Maz, Maya, Unity, Unreal
WORKFLOW QUICK VIEW
iClone Facewrae Facial Mocap workflow
TOOLS YOU NEED
Animation Software
iClone - Realtime 3D Animation Software
  • Version: v7.2.1220.1​
  • 64 bit & DX11 required
  • Platform: Win 7 SP3 / Win 8 / Win 10
  • Release Date: 2018-02-12
  • File Size: 1.13 GB
  • Trial Duration: 30 days
Real-time 3D animation software for digital actors, virtual environments, visual effects with drag & drop editing, powerful physics and easy plug-in compatibility, designed for creativity in storytelling and broadcast production, education & previzualization. Know More
Mocap Suite
mocap Suite - iClone Facial Mocap Plug-in for Faceware
Motion LIVE Mocap and Faceware Profile
Besides utilizing Faceware’s 42 facial tracking ID for realistic facial expressions. The Motion LIVE architecture can synchronously integrate full-body mocap data from industry leading mocap devices to simultaneously drive 3D character faces, hands and bodies.
mocap suite - Faceware Realtime for iClone
Faceware Realtime for iClone is a professional quality real-time facial tracking software designed to give iClone users a simple, cost-effective, and powerful tool for animating characters’ faces. Use a capable webcam to live mocap or a pre-recorded image sequence to drive natural human facial expressions and head movement.
bonus content
Exclusive Bonus Content
This well-designed Boxer character, is a great starter for you to experience the best real-time facial mocap performance. You can also further animate this character's body by layering animations with all of iClone's powerful motion tools!
The Boxer will appear in iClone's default Avatar library once you have installed the iClone Facial Mocap Plug-in Suite.
*The Boxer character has been licensed by Reallusion Featured Developer ToKoMotion. Check out more of his works >
ToKoMotion
Recommended Hardware
High Quality PC Camera: Logitech Brio Ultra HD, 60 fps / Logitech HD Pro C920, 30 fps
TRIAL INSTALLATION GUIDE
The Installation Process has been simplified with the introduction of Reallusion HUB. Grab it by going to the download page and click on the download button. It can be used to automatically install all of the required software:
  • iClone
  • Motion LIVE Plug-in for iClone
  • Faceware Realtime (Trial)
  • Faceware Profile for Motion LIVE (Trial)
SERVICE NOTICE
    General Product Support
    If you have product purchase, or usage questions, then please contact Reallusion support for:
    • Reallusion iClone
    • Reallusion iClone Facial Mocap Plug-in for Faceware
    • Faceware Realtime for iClone (developed by Faceware Technologies Inc.)
    Where to contact Reallusion Support?
    • You may check out the FAQ page first, to see if you can find answers to your questions.
    • If you did not find answers to your issues in the FAQ, then you can submit your inquiries to Reallusion Support, while making sure that you select iClone as the main service category.
    When to contact Faceware Technologies Inc.?
    Faceware Realtime for iClone is the face tracking software provided by Faceware Technologies Inc.
    Contact Faceware Technologies Inc. Support by emailing support@facewaretech.com ONLY if you are a purchased user, and have the following support requests:
    • Failure to activate Trial software to Full license.
    • Need to switch activation from one registered computer to another.
    • Facial tracking related issues.
    *To get support from Faceware, please make sure that you provide the "Ticket" for your Faceware Realtime for iClone, so that they can identify your product version. The "Ticket" is the same as the Serial Number, which is issued to you in the order email from Reallusion.
TESTIMONIALS
"The Faceware Realtime iClone 7 system is a huge win for me as a Faceware user. It is by far the best integration of Faceware I have seen in any package. Combined with the new face keying, you have a powerful combination to deliver truly professional results. The fact that Reallusion has pulled all this off in a single release is truly amazing and I am super excited for the future of iClone."
- Jeff Jasper, Oscar / BAFTA winning team, FX Supervisor “Interstellar” New Deal Studios
